power steering bracket for magnum
mopardemon340
WI
im confused with this power steering bracket. are the 99 ram, van, and dakota PS brackets the same.. im putting the 360 magnum into a 72 demon.
I think the truck pump sits lower than the vans. Take a look at the Magnum builds thread. I think I posted a pic of my van set up
the van brackets are the ones that hang lower, the truck bracket will get into the battery and you have to trim down the batt. tray to use it. one draw back on the van brackets, is that you will have adjust the belt tensioner to use the van belt. the van has a smaller ac pulley than the truck. the ram and dakota brackets are the same, but the durangos are different. just dont know in what way. dave.
