power steering bracket
I do.
But, what style pump do you have, that your looking for the brackets?
Federal or TRW?
I have brackets for all three types of pumps PM me if you still need them
I might too but would need to see which pump you have. If this is a conversion from a 6cyl to 8 cyl, you'll need a pulley also.
yeah i converted from a /6 to the 318 and i high flow water pump that mounts to the timing cover... im not sure how you can tell between the different water pumps
I think we're confusing pumps here. You're looking for power steering pump brackets, correct? If so, there are three different manufacturers of power steering pumps around that year. Each use their own brackets. The Federal and TRW pumps share some common brackets but not usually pulleys. The Saginaw pump uses completely different brackets and pulleys. We're presuming you have the '67 cast iron water pump since you didn't say that it was converted to the aluminum one but if you have changed that over too, it takes a completely different set of brackets and pulleys for each power steering pump type for the aluminum water pump also. I know it sounds confusing but basically, if you have the '69 and earlier cast iron water pump, it needs the proper radiator, pulleys, and brackets that go with that design. If you have the '70 and newer aluminum water pump, it will need a complete set for that design. You can't mix and match as things just won't line up. 6's and 8's don't share any common brackets, pulleys, or radiators either, regardless of year.
yeah i have the Saginaw style pump and i am using the aluminum water pump, so i think that should clear everything up thanks
You may have problems trying to find late brackets that will fit an early pump. It might be easier to just get a good used '70-up pump with the brackets you need still attached.
