You'll need an extra pulley on the crank, the power steering pump and its bracket, steering box, and the shorter steering column.
Shipping to Canada is going to be a lot, but I have a steering box and pump out of my '66 Dart. You'll need to source the rest though.
I've also seen kits to stuff a late model EPS unit under the dash, but it probably takes some fabrication.
