[FOR SALE] Power steering parts
MidnightSwinger
Woodland CA
Used small sector gear box from my low mile/barn find 67 Barracuda. Box was nice and tight with no leaks. It has a quick and dirty paint job as I planned to bolt it back in. Looks really good, but I just pressure washed it and rattle canned it. Includes the two factory hose clamps if you want them.
$85 plus shipping
64-69 Small Block Federal Pump, and brackets from the same 67 Barracuda as above. It didn’t leak, it didn’t make any noise. It was also pressure washed and rattle canned. Very clean inside, and the cap cleaned up nicely.
$75 plus shipping
PS004 70 and up small block Saginaw bracket kit, new in package and all contents present.
$40 plus shipping
Used PS coupler from a 74 swinger, grimy but complete, definitely would rebuild.
$50 plus shipping
I believe the brackets and pulleys are different too. Using the later ones along with what you have might do the trick.
The brackets and pulleys are the same 64-69 I believe. I know the mounting brackets are for sure. I appreciate the added info, I didn’t know the early A’s used a larger return.
