[WANTED] Power Steering Rear Bracket Horn Set Throttel Brackets More
bradfields
Indiana
Looking for the rear power steering pump mounting bracket for the setup in the picture. Also need the following stuff for a 71 Demon 340
  • 340 throttle cable and return spring brackets
  • horn set
  • one headlight retainer ring
Please let me know what you got. Thanks
Ooooooops, also need a coil bracket and the fitting that the fuel line screws into on a Carter AVS, I think an AFB uses the same fitting?
