Hi I have a 72 duster with power steering currently and I have a manual steering box I would like to install. If I get a mancini racing adaptor is this all I need to make the transition or do I need an entire manual steering column? Thanks!
Are the hex nuts under the pitman arm both the same size ?
If not you'll need a pitman arm.
Yes, Redfish is right. Of course you will need to compare the 2 steering gears to make sure that you've got one that is an easy replacement for your power unit. But as long as it is you should be in business.
