stormydart
I installed a power trunk release on my 72 dart. What gauge wite should I run to the back. Thanks
I'm thinking that actuator has a 4 or 5 inch pig tail lead made onto it. Its about 18 gauge? Whatever it is should be sufficient.
Go to the junk yard and find an 80s Chrysler. Open the glove box and yank the switch along with the electric trunk lock. Tap into your passenger door jam switch for the hot wire. Go ahead and grab the jam switch also as it will have a double plug. Very easy to wire up. The most expensive part will be the roll of wire you need to get to the trunk from the switch!Please show pics and parts. I'd love to do this.
