[SOLD] PowerMaster. XS Torque Starter
1969GTS340
Akron, NY
Powermaster 9523 XS Torque Starter for 1965-87 Chrysler (Clockable) ($300 new) $225 shipped in USA.​
Used for one race season.
Powermaster's highly efficient XS Torque starters feature extra-powerful motors that churn out up to 200 lbs.-ft. of torque. Coupled with their 4.4:1 gear-reduction ratio, that equals reliable cranking power for engines, up to a whopping 18.0:1 compression ratio. These starters come with a billet adapter/mounting block for durability. They'll also clear your oil pan if the OE starter did. Some models are available in a chrome plated finish. Starter dyno test results are included. Order the replacement designed for your vehicle application.
Edit. The part number I posted is not correct. This is a 9513. Not 9523. The difference being, the 23 has a nose cone, 13 does not. Sorry for the confusion guys.
