Pressing clutch down I hear this..
Manual Transmission & Clutch Discussions
  1. MAPS
    MAPS Well-Known Member
    566
    140
    Nov 1, 2015
    canada
    Local Time:
    9:28 PM
    Good morning Moparites...
    I'm sure ( praying now) that I'll get an answer from someone here as I usually do.
    8 out 10 times when I press the clutch down to shift gears I hear a a clicking sound, much like stepping on the high beam switch to go from low beam to high beam.
    In fact the first couple of times I actually looked to see if somehow my foot was touching the switch on the floor...
    I have no idea what this sound is. Any input, gradually appreciated.
    MAPS
  2. Murray
    Murray FABO Gold Member FABO Gold Member
    1,773
    1172
    Apr 19, 2010
    San Jose, California
    Local Time:
    6:28 PM
    You need to have the car on the hoist with someone working the clutch and another watching the linkage looking for something loose or binding.
  3. Joey4speed
    Joey4speed FABO Gold Member FABO Gold Member
    757
    523
    Jul 17, 2018
    Jersey
    Local Time:
    9:28 PM
    My clutch assembly clicks (more like a clank) pretty loud sometimes when I press the foot pedal down. Usually the pedal will not return fully and have to pull it up by hooking my toes under the pedal, then it snaps up. This has little to do with actual clutch engagement, this happens afterwards.
    I was told that the small upper shaft, where the spring mounts, is probably worn or has a flat spot, causing this. Supposedly it has nothing to do with the external linkages, which are new from Brewers.
    I would have to drop the entire assembly from under the dash to get to it. Its supposedly not an easy removal, not to mention the repair itself.This shaft, or pin is not very accessible and is pressed in.
    Thats what I was told, I really dont know much more about it. I would prefer to have a replacement part in hand before I even dropped the pedal assembly and layed up the car.
    Not sure if this is kind of what you are experiencing.
    Maybe someone else here has also had this issue.
    Hope it helps.
    • Agree Agree x 1
    • greyghost340
      greyghost340 GreyGhost 340
      170
      39
      Dec 5, 2014
      New Balimore MI
      Local Time:
      8:28 PM
      There is a little black clip that holds the clutch rod in place. Check to see if that clip is worn and catching on the linkage or is about to come off?
    • krazykuda
      krazykuda Well-Known Member FABO Gold Member How-To Section Editor
      53,605
      18556
      Aug 20, 2007
      Orland Park, IL
      Local Time:
      8:28 PM
      What's that clicking noise????
      • Like Like x 2
      • Kendog 170
        Kendog 170 Let the boy go !
        1,095
        693
        Mar 10, 2016
        Tewksbury Ma.
        Local Time:
        9:28 PM
        I had the same thing as post #3. When I went to different style clutch and removed the heavy spring it went away.
      • Professor Fate
        Professor Fate Push the button, Max...
        849
        1072
        Jan 13, 2020
        Wisconsin
        Local Time:
        8:28 PM
        Is yours a later A that has a clutch safety switch on it? If so, check the switch/bracket for alignment and action when the pedal is depressed- could be something as simple as a switch adjustment or replacement.
      • Oldmanmopar
        Oldmanmopar Going left turning right FABO Gold Member
        8,404
        4571
        Jan 8, 2009
        Danielsville Pa. 18038
        Local Time:
        9:28 PM
        Your over center spring is dry or wore where it pivots on the assembly, My first guess. The first thing you need to do is make sure you have the correct parts in your car. There are several different pedal assemblies with different springs and pin spreads for different years and different motors. There are also different bell housing pivots and forks and the geometry is totally different. I had a guy come here and he had a new clutch put in and now his fork rubs the exhaust with the new fork. There is a late and early bell pivot from what I recall. They have different pivots which take different pin spreads on the pedals. I have been working on these cars a long time and still learning myself. Is your engine and trans original to your car? Below is an example of just two different years A and E body. Even the pivot ball attachment bracket is different on the side.
        If your car just started this it is more than likely a worn and dry spring pin. I see cars come in all the time and the linkage adjustment rods are dry and wore. No one ever greases the linkage until its to late. Especially under the dash.
        • Like Like x 1
        • Thanks! Thanks! x 1
        • Agree Agree x 1
        • Daves69
          Daves69 FABO Gold Member FABO Gold Member
          4,970
          3092
          Feb 20, 2011
          WestOfChi
          Local Time:
          8:28 PM
          You might also look over the firewall and inner fender at the ball stud for any flexing and sheet metal popping.
          Some more click comedy........
          • Like Like x 4
          • Agree Agree x 1
          • MAPS
            566
            140
            Nov 1, 2015
            canada
            Local Time:
            9:28 PM
            Thank you to all.
            I finally fixed the vibration in 4th at 3K rpm and real happy about that, I'll look into the clicking sound soon.
            MAPS
          • Kendog 170
            1,095
            693
            Mar 10, 2016
            Tewksbury Ma.
            Local Time:
            9:28 PM
            What was your vibration ?
          • MAPS
            566
            140
            Nov 1, 2015
            canada
            Local Time:
            9:28 PM
            Greased U joints saps that they should be greased every 6 months if you are putting the car away for the winter and balanced the driveshaft again.
            Hope that helps.
            I know how horrible I felt at 2800,2900 max 3K rpms the whole thing would start to shake, vibrate and scare the bejesus out of me until I just floored it the last time and said, it blows stops or clears up.
            Nothing happened but harder vibrations.... On my way to Dr Driveshaft... And finally my nightmares were finished.
            MAPS
