lightweight
Active Member
Is there special bolts that hold the pressure plate to the flywheel that have a shoulder or something that bottoms them out when torqued? Or some kind of spacer between the pressure plate and flywheel. I am converting my dart to a four speed and trying to install a mcleod clutch and pressure plate. I have never installed a clutch before and and wondering if I need some sort of shims to torque the pressure plate down or can I just use grade 8 bolts, and torque the pressure plate with the clutch between and torque to the fly wheel? The clutch set up did'nt come with shims or bolts and I cant find it in any papers the clutch came with. Thanks in advance.
