Getting ready to rebuild my slanty. I have always primed the oil system on my V8s through the dist drive hole with a long hex shaft. What is the best way on a slant 6? Thanks for any advice.
Yea that's probably what I'll do is just Jiss up all the good parts with some slickem and go for it. Thanks guys.Bear in mind the factory didn't fiddlefutz around with any steps like this. Oil and filter got installed, engine got started, and that's it.
The pump is directly geared to the cam, the dizzy has nothing to do with driving the pump, only shares using the same gear on the cam itself.How about using an old distributor remove the drive gear hook the top to a drill and spin it?
