vernair
Member
Hi everyone.
I had this professionally built for my old 1965 Plymouth Barracuda to replace the stock 273, but I ended up selling the car before putting this in.
It is BRAND NEW, 0 miles on it. It's only been broken in on the stand at the shop. I paid about $5k for it just 6 months ago. You can hear/see it run on the stand here:
PHD The Speed Center | Facebook
(Scroll down to July 2)
Here's the specs:
315 hp / 330 torque
Block is Line honed/bored and honed with torque plates to .030
New Flat top cast pistons
New Moly rings
New Clevite bearings
Reman connecting rods
Reman crankshaft machined .010/.010
Rotating assembly balanced
New Comp Cams Hyd Flat tappet camshaft and matching lifters
Custom built cylinder heads with
New valve guides
New oversize stainless steel intake valves
New stainless steel exhaust valves
New valve springs to match the cam
New viton pc valve seals
New Hard exhaust seats
Performance valve job
CBN surfaced
Speed master 1.5 ratio shaft roller rocker arms
New .080 wall push rods
Mopar Performance cast aluminum valve covers
New Aluminum intake
New Quick Fuel 600 cfm carb
Mopar elctronic ignition
New plug wires
Taylor wire looms
New spark plugs
New oil/filter
Balanced and Blueprinted
This is a perfect, ready to go, show quality, performance engine. Located in Long Beach, CA. Comes with used but in good condition motor mounts.
$3900
Thanks.
Vern
Here's the specs:
315 hp / 330 torque
New Moly rings
New valve guides
CBN surfaced
New Aluminum intake
New plug wires
Taylor wire looms
New spark plugs
New oil/filter
$3900
Thanks.
Vern
