pro comp heads
earthmover
in the tire smoke
nc
does the inday 440-2 single plan intake fit this heads..intake is max wedge size and heads are cnc..thanks mike
the pro-comp has the extended intake runner so i would assume that you have to use the 400 intake. ok, their add says they work with conventional intakes but what does that mean? they also post that there is a $60 extra charge for the "B" head so know i'm just as confused as you are.
thanks ..hey bob hows it going?????i sent your buddy some pics..hope you have a great new year..:icon_smi:
hey bob i'll go ahead and order some this week from a local store so we can go ahead and get it in..:glasses7:
I have the Indy -3 intake on a set of procomp heads. Low deck block. So if its going on a 440 block, they will fit
