pro parts vs fenderwell
Mopar Exhaust Systems
  1. forced 340
    forced 340 Well-Known Member
    734
    42
    Aug 29, 2011
    michigan
    Local Time:
    11:42 PM
    Just a few questions. If you had a choice between pro parts semi fenderwell headers, and full fenderwell headers (both 2" tubes), what would you go with? if you run the p.p. headers, how tall of a tire can you run? is the trans easy to get out? ground clearance? I know with full fenderwells, you'll need a 165ish tire. thanks for the info gang!
  2. vitamindart
    vitamindart Well-Known Member
    1,298
    378
    Jun 11, 2010
    Vernon,Wisconsin
    Local Time:
    11:42 PM
    had both, noticed a pick up in et and lower engine temps when I ran the fender wells. don't remember any issues rubbing tires with the pro parts.
    were a little more difficult to seal up but not bad. my pro parts were coated inside and out and still caused the engine to run 15-20 degrees hotter in traffic.
    no other change than fender well headers and the temps were well under 200 no matter how much traffic I dealt with.
    fender well headers equal shitty ground clearance, tire rubbing & exhaust routing issues but, that's what I prefer.
    • Like Like x 2
    • SGBARRACUDA
      SGBARRACUDA ROY FABO Gold Member
      19,642
      8093
      Dec 7, 2006
      PLANT CITY FL. and PERRY GA.
      Local Time:
      12:42 AM
      I’ve ran both a few times in my lifetime. IMO? It is a no brainer. Pro Parts every time. No tire issues and you don’t have hack the hell out of your inner fender wells. And you can actually work on your engine without getting third degree burns.
      • Like Like x 1
      • Agree Agree x 1
      • famous bob
        famous bob mopar misfit
        19,411
        8492
        Aug 14, 2011
        okla
        Local Time:
        11:42 PM
        I ran dougs and hooker "proparts type" headers on a hemi superstocker , had tire rub w/ both !
        • Like Like x 1
        • roccodart440
          roccodart440 Well-Known Member
          5,749
          4734
          Apr 19, 2010
          Local Time:
          12:42 AM
          I'd wait until I had the money to buy a set of under chassis headers.
          • Like Like x 1
          • SGBARRACUDA
            19,642
            8093
            Dec 7, 2006
            Local Time:
            12:42 AM
            Never knew Hooker made a set of Pro Parts style headers. If you use the Pro Parts which was the old Herb McCandless headers, tire clearance is not an issue. Unless your trying to run 17x40 Ground Hogs on the front!
