Advice Needed - I have started a Kelsey Hayes disc brake swap and have realized a problem. Where the upper control arm bolts and camber adjusters meet the frame/support it appears I have a lot of rust. Both bolts snapped when I was trying to remove them. I think the support may be weakened from the rust. I'm not sure what you call that frame support but the control arm runs through it at the bottom and the shock goes through it at the top. Is this a known problem with A Bodies? Is it a replaceable part (welded in)? and what is it called?
Thanks for your help.
Greg
Greg
