Problems checking mesh 8-3/4
Transmission and Drivetrain Tech
  1. 67charger383
    67charger383 Well-Known Member
    60
    16
    Feb 26, 2020
    Maryland
    Local Time:
    6:56 PM
    Every time I seem to have it right the gears feel sticky and grind when I turn them. Help?
    I need instructions on how to do this as my Yukon directions are trash
  2. Rmoore
    Rmoore Well-Known Member
    417
    249
    Nov 14, 2018
    Gun Barrel City, Texas
    Local Time:
    5:56 PM
    What is your rotational torque on your pinion ?
  3. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    16,457
    4856
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    5:56 PM
    R these new gears u set up? How about some pics. Kim
  4. pishta
    pishta I know I'm right....
    18,267
    7741
    Oct 13, 2004
    Tustin, CA
    Local Time:
    3:56 PM
    your pattern should be in the middle of the tooth root on both sides. Sounds like you are too deep?
    Remember to load up the pinion before you turn it to make the mesh pattern. You want some resistance on it so it will print under load.
  5. oldkimmer
    16,457
    4856
    Nov 11, 2006
    Local Time:
    5:56 PM
    Looks like he doesn’t want any help. He has been on since and ignored this thread Kim
  6. pishta
    18,267
    7741
    Oct 13, 2004
    Tustin, CA
    Local Time:
    3:56 PM
  7. 67charger383
    60
    16
    Feb 26, 2020
    Maryland
    Local Time:
    6:56 PM
    Sorry I've been busy the past few days.
