72duster72
is it possible to use hyper technic distance with a small ProChawith meth injections it will have aluminum heads
Sure, it's possible with conservative boost levels and proper ring gaps. Hypereutectic's are stronger than cast pistons but more brittle because of the higher silicon content. You have to keep detonation under control.
Forged pistons are generally a better choice for boosted application.
I do not have the money for such things and the real world has changing weather conditions and sometimes, really crappy gasoline.
