Procomp rockers--any good??
Mopar Performance Issues
  1. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    7:22 PM
    Anyone ever or are using procomp rockers, I believe they are the bushed type not needle bearing. This is for 470 stroker.
  2. goldmember
    goldmember Well-Known Member
    349
    8
    Aug 13, 2004
    Local Time:
    1:22 AM
    Run Forest Run!!!!
  3. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    17,614
    5494
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    7:22 PM
    ...................x2............................kim........
  4. moe7404
    moe7404 moe7404
    688
    13
    Dec 14, 2012
    wichita, ks
    Local Time:
    7:22 PM
    i have read the one to use is the Harland Sharp Rockers.
  5. Abodybomber
    Abodybomber Breaking street machines , since 1983.....:) Legendary Member
    31,576
    10470
    May 21, 2011
    Arroyo grande ca
    Local Time:
    5:22 PM
    Just out of curiosity,called the Scummit line a while back.Asked what he thought. His response,priceless. " I wouldn't run them on my Briggs & Stratton lawnmower" I considered it ,truthful advice.
  6. mopardude318
    mopardude318 Well-Known Member
    9,832
    1001
    Jan 7, 2005
    Gilroy, Ca
    Local Time:
    5:22 PM
  7. famous bob
    famous bob mopar misfit
    18,316
    7718
    Aug 14, 2011
    okla
    Local Time:
    7:22 PM
  8. 1Fast340
    1Fast340 Well-Known Member
    1,189
    401
    Dec 30, 2011
    Sweden
    Local Time:
    2:22 AM
    wouldnt touch them. there are lots of good rockers out there harlandsharps are real good, comp has some nice steel rockers and crane golds are also good unless you run into a set from the period when they had bad adjusting screws.
  9. airwoofer
    airwoofer Drivetrain limit explorer
    2,208
    39
    Jan 4, 2011
    Huntsville, AL
    Local Time:
    7:22 PM
    If you are using Indy 440-1 heads I can make you a killer deal on NEW Indy rockers, studs, hold downs, shafts. Also a NEW set of Comp roller lifters and 9.750 pushrods. Send me a PM if interested.
    [​IMG]
    [​IMG][​IMG][​IMG]
  10. Oldmanmopar
    Oldmanmopar Going left turning right FABO Gold Member
    8,994
    5448
    Jan 8, 2009
    Danielsville Pa. 18038
    Local Time:
    8:22 PM
    They are Junk. I was told to try T&D I've run 686 lift with them on the street and they take the abuse like a champ.I know am running a 720 and no problem yet. My Harlen Sharpes didn't last a month on a 630 lift. I also had good luck with Norse and comp cams ductile iron. Stay away from any aluminum rockers They will fail. They look good anodized if your not going to run valve covers. I always see pics of pretty rockers all colors. But when the break they are all the same color silver.
    I have already seen guys put pics of their motors with the covers off under there hoods at shows. Just so you can see their pretty rockers. Go with strength not looks. and I wouldn't give hughes a thought unless you hire someone to keep the lash adjustment up to spec.
    • Like Like x 1
    • Oldmanmopar
      8,994
      5448
      Jan 8, 2009
      Local Time:
      8:22 PM
      I run an Indy top end If I would have put their heads on out of the box my engine would be junk. Their machine work is worse than bad. Russ is an A$$ to deal with and he thinks he knows it all. Just Google Indy screw ups. And see what customers think of Russ at Indy.
    • pishta
      pishta I know I'm right....
      19,101
      8525
      Oct 13, 2004
      Tustin, CA
      Local Time:
      5:22 PM
      T&Ds are made by an ex Harland Sharpe guy. Basically took the HS design and made all its shortcomings better. Probably the best big name rocker out there. Their US/German roller bearings are worth more than Pro-comps full rocker setups.
    • JimmyV
      JimmyV MOPAR!!
      233
      16
      Mar 28, 2006
      Spokane Valley WA
      Local Time:
      7:22 PM
      I have never ran procomps but i have ran proforms for a while and like them never had a problem with them could have been the luck of the draw though
    • famous bob
      18,316
      7718
      Aug 14, 2011
      okla
      Local Time:
      7:22 PM
      still no one w/ experiance running them? a lot of bad mouthing for no exp.
      I had proforms on a 600 h.p. 406 , they wore out pretty quick, w/ the 292 roller.
      just a discussion here------------------------------bob
    • ohiocowboy1277
      ohiocowboy1277 Well-Known Member
      153
      15
      Dec 23, 2010
      ohio
      Local Time:
      8:22 PM
      i had them in a mild 360 for 2 weeks running comps extreme energy 268h cam 3 were shattered and 3 others had ate the bushings and this was not an oiling prob . replaced them with harland sharps ran it 2 more years and sold the engine to a kid with a volare . that was 5 years ago and its still running
    • daredevil
      daredevil Well-Known Member
      11,410
      148
      May 19, 2007
      S/w Houston
      Local Time:
      7:22 PM
      I hang out at my buds machine shop and have seen 3 motors ruined by these rockers. Adjusters are the problem not the fulcrum.Search proform on here. There are horror stories.
    • moturbopar
      moturbopar Well-Known Member
      603
      15
      Apr 1, 2011
      mesa az
      Local Time:
      6:22 PM
      Ran their stainless rockers with no problems. Had them on mopars, chevies, and fords. never a problem. None of them race motors, and none with crazy spring pressure either.
    • 65-440
      65-440 Well-Known Member
      1,443
      210
      Apr 11, 2010
      va. beach, va
      Local Time:
      11:22 PM
      Do not get them ! A buddy of mine put at set on his big block '69 mach 1, broke 2 just driving around on the street. Did not even get a chance to abuse them. Called the company and they sent him a brand new set. Less than 200 miles later, same thing. Company will not return his calls now. He has since put a set of comp cams roller rockers on, several thousand miles and much abuse later, still running good !
