proform 750
aaronk785
westmoreland ks.
Have a question about a preform 750 I bought awhile back. I opened it up to jet down a bit and noticed that it had screw in afr there are 6 other tapped holes in each metering block with nothing in them. 3 on each side. Is this normal and is this for further tuning. Or did they forget them at the factory?
Those are emulsion bleeds. Your plates only have 3? Most of the Pro Form blocks I've seen have 4 per Venturi.
If you want to run the emulsion they have you can run that. IIRC, those blocks have a .028 hole in them. I usually start with a .028 hole in the 1 and 3 hole from the top and block 2 and 4. But it depends on how much air bleed you have and jet sizes etc.
