Progress pics
rcottick
Sterling Heights, Mi
ok Im going to try this and see if it works.
Anyways I bought the caar last fall and started work right away. Went on hold till this spring since the snow flew. I have completly blasted outside and underneath epoxy primed and statrted the body work at the front corner. I have to replace the floorpans as they are shot. The tail panel had been hit at one time so that why I am replacing it.
This is the first major resto I have ever done and alll work is done by ME wooohoooo....Plan is going to be to mini tub and relocate the springs before I put the new tail panel back on. the its paint time. Going to go back to Fe5 red with a black and white interior. Engine will be a stroked 340 with 4" crank (416) I believe E-heads with TTi headers and full TTi exhaust. so here we go...heres the pics. Hope to have er done by next spring
Ron
looks like your are headed in the right direction. Good luck.
looks good. huh, the taillight panel on my wifes duster looks like that too---i wonder why that happens to them, seems like a weird spot for rust to form.
--chad
