hey jim, whats up? you about ready to drive that cuda? lol. dave.
I have been researching that. I intend to eventually install air conditioning, but that's probably down the road a little. I could go ahead and mount the compressor to use as a idler pulley. You can also fabricate an idler pulley to go in the place of the power steering pump.Have you figured out the belt setup with no power steering? I will be running a/c with no power steering on mine so Im a little curious how it will be done. \
The manifolds on mine are from a 92 Dakota with the 2 1/8" outlets. Yes, the old manifolds will work on the Magnum heads. I had mt 318 LA manifolds bolted up for a while. Look in the exhaust section for threads/posts by Treblig. He has been pairing a passenger side Magnum manifold with 340 HP manifolds.
