!!! project part out !!!
project360
Tucson
IF YOU WOULD LIKE THE LARGE ITEMS WE CAN DISCUSS SHIPPING, most items shipping included, thanks and happy shopping....
hilborn 2x4 blower style scoop ... $ 100
one 360, one stock 1979 complete block less valve cover and intake, needs rebuilt, $150 and you pull it
and one .060 over 1973 block w -.010 crank installed with new clevite bearings, new Crower Pro Street solid lift .521/.528 Adv. Duration 294/298 @.050 .243/.245..112 LSA, new Cloyes true double roller..........comes with stock cast pisons(used)on rods not installed $350, engine stand included.
1974, 904 Trans needs rebuild... taking offers
small block heads cast 027596 with 1.8/1.6 vavles w. aluminum keepers and good springs off running 1978...$80.00
A body, 111 in. Weld in sub-frame connectors...80.00
HEI dist, pulled from running 360, has HO chevrolet cap....$40
B&M Pro ratchet shifter, pistol grip with new 5 ft cable.....$150
Deep truck pan, small block $20.00
Leaf spring relocation kit $80.00
Comp engineering A body fwd motor plate....$ 80.00
NHRA approved bolt in drive shaft hoop, taking offers
8.25 Nitro Gear 4.10s in box......$100
8.25 Nitro Gear master rebuild in box..$25
8.25 LPW ultimate 10 diff girdle NEW $180
OR...8.25 suregrip complete, LPW girdle with 3.55s, 27 spline, and leaf relocation brackets installed... $ 450
1974 Plymouth Scamp.. roller, DISK BRAKES PWR STEERING........ $600 obo
OR YOU CAN HAVE IT ALL FOR $1500
only 150 views !!! some one take this stuff... 1000 for everything
pics on request by txt or email
How about some close up pics of the scoop? Is it a vintage one or is it newer? Thanks
