Project "Pig Pen" 1967 Dart Gt
67Dart440GT
Seriously Long Member
The body shop
Well here we go again... I bought another 67 Dart Gt. Hopefully I can keep after this one and keep it rolling along.
Here is a little back story on the car.
I have been looking for a 67 Gt for several years now and about 4 years ago found one in the Chicago area. The guy wanted a ton of money for it but I figured I'd look at it.
My father and I headed down about 2 years ago and we were pretty unimpressed with the car as it needed a ton of work for the money. For some reason the guy wanted tons of cash for it. We said thanks but no and moved on.
Fast forward to this fall. I noticed the same car, same guy trying to sell it again on Facebook marketplace. Only this time a bit better if a price. I contacted him again and set a time to see the car again. Still the same mess, only a much better price and delivery included. We made a deal and the car is here.
The car is originally a slant 6 Gt white with black interior. Fender tag is missing unfortunately. It has been swapped to a 383 727 8 3/4 set up that was done horribly. I honestly can't wait to show you all the photos of this Chevy mechanics handy work.
Plans for the car include using what I have for awhile and getting the car running and driving safely. The car needs a ton of metal work but the bones are decent. Frame rails are good and floors solid other than the front foot wells.
I will upload pictures as I tackle each task and we will all get to laugh at the handy work of the previous owner.
Here are a few updates. I get to correct some of the previous owners handy work in the future. Check out the driveshaft length.
Tonight I started a repair on the common door striker issue. I am welding in a big washer and fixing all the cracks. This is temporary until I actually start a full restoration. This car is going to be something I drive for awhile so I am just trying to make it functional.
I decided to do a bit of a temporary repair on the striker today. Door shuts and fits for now to at least make it functional!
I got side tracked and added a nice ceiling mounted 50k btu furnace. Pics to follow!
Heck yeah man! You got them boys ready for a big Christmas?
I got some time this weekend to work on pig pen. The previous owner installed an a body 8 3/4 rear end but forgot half the bolts and used some ridiculous shock mounts with no mount for the shock....???
I pulled the rear, I have new stuff to install it correctly but I wanted to start cleaning the bottom of the car. Most of the under cost removed. I will chassis black it and probably just re undercoat the back so I can install the rear end. Rear will get painted black as well but I am not going to disassemble it and blast and paint. I am trying to keep this cheap but steady so I'm not stuck on a ten year project.
Pig pen has been hiding some dirty little secrets! Can you see the frame rail damage?
Here is one quick coat or Eastwood rust encapsulator. I will undercoat it after a few days.
Here is some undercoat I sprayed. I was not happy with the rattle can autozone stuff and don't have a schutz gun anymore so I actually used some flex seal. Sprays nice has a good texture and seems to have amazing vertical stability.
Pig Pen is getting closer now. I gave him a rattle can rear end rebuild. New leaf springs and bushings. Once I get it mounted I can measure for the driveshaft.
what springs did you go with? following!
Here are a few updates. Drive shaft is done, radiator is here, got a new intake swapped and some second hand valve covers.
Old big block looks clean on the inside!
It was supposed to be rebuilt from what the last guy said. It needs a good cleaning though. Not sure why it looks so good inside and looks like a pig Pen on the outside?
Cause it was rebuilt and then someone didn't give a darn what it looked like. Now you have it and all that's gonna change.
