prop valve
res1vw21
It's only metal
Renton Wa
Does any one know if there is a visual difference between the drum brake and disk brake prop valves? I have a few different ones sitting around and would like to be able to identify them. Thanks
The disc brake valve is larger than the drum brake valve and shaped kinda funny. The drum brake valve is smaller and pretty much just a rectangle.
good to know, someone messed up the one on Tara's dart and I have a few sitting around and I couldn't remember which were which.
