cc68cuda
New Member
What we are selling is a street legal drag car with a TITLE! It is back half with ladder bars and single adjustable, alteration front suspension with qa1 double adjustable. 9" Ford rear with a 4.11 gear, Strange 35 spline axles and spool, Mark Williams nodular center with aluminum pinion support, Wilwood disc brakes both front and rear. 10 point mild steel cage with nice sheet metal work. Factory dash, door panels and new carpet. Wired for nitrous, digiset timer and has a MSD 6530 programable box. Has front plate and two travel limiters. The car is all steel except the hood and weighs 3200 lbs with 175 lb driver. Brand new 15 X 14 Weld Prostars on rear with 31 X 18.5 X 15 Mikey Thompson Sportsman Pro tires. Brand new Weld Prostars on the front with M/T's also. The car has a brand new Hurst pistol grip shifter. The car has been 1.25 60 foot and 5.50's in the 1/8th with a w5 small block and glide. (We have the glide mount) The engine and Trans in the car now is a 360 bored .030 over, internal balanced, srp flat top pistons, arp bolts, comp cam flat tappit hy. 292, 299 duration .525 lift 10.3 to 1 compression, Mopar aluminum heads, Mopar M1 intake, Jegs roller rockers, Electric water pump, Holley 750 ultralight carb, torqueflight Trans with manual reverse valve body, 3800 turbo action converter. $16,000.00 cash offers only. Thanks
