Pulley question...with an ATI balancer...
dusterdoug
Tracy, CA
Anyone have an ATI balancer with a manual water pump on a small block? With a mini denso alternator as a bonus question.
What pulley combos y’all using?
Will a OE pulley even work on an ATI balancer??
Thank you in advance!
I was unable to put a manual water pump on with my combo. I used the Doty Mfg pulley. Mini denso and PRP electric wp. I tried the manual pump, but it was coming nowhere near where I needed
Yes, the stock pulleys will work with the ATI balancer...
Stock pulleys will work if your balancer is setup for it....I have my ATI balancer setup with a Chevy bolt pattern for more pulley choices.
