Pulleys/accessories/brackets, et al
maw
Member
Hi folks,
When we bought my sons '67 Dart the original 318 was dead and the PO had partialy stripped the engine down. We're in the last stages of getting it back on the road with the new 360 but have no info on what brackets hold what where. Can someone post a couple of pics of the front of their engine showing placement of the alternator, power steering pump, and air conditioning compressor, along with the brackets that support them.
Many thanks,
Mark
Here are a some shots.
This is the front of my engine the alternator is not installed bu the brackets are on the engine in the correct location.
The power steering pump pictures are from another For-A-Bodies-Only member when I had a question about the power steering pump brackets.
Thank you much, that helps. The water pump is different but close enough.
Anyone have the factory air conditioning still on their early Dart that could supply a couple of shots?
Thanks, Mark
