rmchrgr
Skate And Destroy
Been doing a little research, not exactly sure what I need. Gathering parts for a large maintenance project to keep the Dart running right.
I have to replace my leaky, chirping water pump. I found the MP 6 blade one pretty cheap (almost the same price as a regular stock replacement) At the same time, I want to ditch my A/C and power steering so I will need to reconfigure my pulley and belt system for a clean install. I already have a new Flaming River box and Firm Feel adapter I intend to use. This is for a '71 318.
As an aside, while the lower part of the column is apart, I'm going to pull it out, replace the turn signal switch, swap in my floor-shift collar and install a floor shifter. I have all the parts to do that already.
Can anyone confirm for me what pulleys and belts I need to do the job? I'm not opposed to spending the coin on the right pieces from a resto place but obviously I need the correct ones. Part #s for the belts would be great if possible since those are likely available at a genearal parts store.
Thanks,
- Greg
Thanks,
- Greg
