pulleys
ZKDEMON
I have a 414 small block and plan on buying a champion radiator. Not sure what pulley set up I should use so am I am thinking of buying a CVF pulley kit. Has anyone used this setup?
im not sure if the radiator will be the deciding factor
what accessories are you running ?
did the motor not come with pulleys or are your deleting/adding stuffs?
depending on if you will run a shroud or not the fan spacing may need to be adjusted back or forth aswell
This is a street car no accessories just the altenator I going to try it without a shroud and I will have to adjust the fan spacers. I didn't have any pulleys with the motor. I have a single groove pulley that is 6 1/2 inches across and a single groove water pump pulley that measures 6 7/8 across they just about touch. That is why I am looking for a pulley set up and I need to buy a radiator also.
