[Found!] Pullies
No two groove pump pulley on a 340, all 340's had a single on the pump even with air 70 and up. The crank was three groove
Any Sb car or truck with a/c from about 76 up will have a double groove w/p pulley. Especially in the 80s. Depending if ur using the Sanden pump. I may have what u need. I have a bracket kit for the Sanden also. Kim
First I think I need to back up. First call
Classic air and find out qhat pulley set up foe there application. Ill find out what I need and probably get with you. Let me know if you have read this and I will end the post
