Push rod?
Kevin D.
Bowdoinham,Maine.
I bought a set of used push rods from a member.They are ball and cup and in good shape.But they are oil thru.Small hole in each end,But are correct length.Can I use them even though I dont need oil thru push rods.Your input appreciated,Thanks Kevin.
whether oil goes thru the pushrod is going to depend on the lifter.....need to check the lifters...
