earthmover
in the tire smoke
guys what your thoughts on push rods should I thought about the comp cam mag. ones then I thought about getting some made....I have 1 to go by with almost 1 comp. tread showing but dont know if thats good enough or not....if I need to have some made whos gets the :cheers: from you guys and whats the contact info...almost ready to set motor down in the car just need push rods.... also what would you guys run as far as plugs I have used auto 63and 65..I plan run 110 fuel and what should I set the timing at once started dist.. locked out so whatever total.....thanks
