Pushbutton transmission
CSM13
New Member
Nj
I have a 63 valiant slant with a 904 pushbutton trans. The rebuilder says the front bearing is wiped out on the pump I can't find parts what other year transmission will fit? Or does anyone have a good source for parts?
You could also try TSR Racing Products, they're in New Hampshire. They had all the parts I needed when I rebuilt my '65 cable-shift 727.
A & A Transmissions or TSR Racing Transmissions in New Hampshire . TSR did mine . Great people , family owned . Ask for Craig Munroe .
You’ll need parts from a 63-64 pushbutton.
Did they do an input shaft/spline count change on the 904 like they did in '67 to the 727?
904 changed the input shaft dia and spline count and converter pilot dia between 67 and 68. This applies to both the slant six, and the small block.
