Mike Paradise
Member
I'm looking for input on a pusher fan, I have a 69 Dart 383 GTS, aluminum heads, intake & new aluminum radiator, everything is new, has a 165 degree thermostat. The car runs like it's supposed to with no overheating issues as long as it's moving along. During slow moving parades it wants to creep up to the 230-240 range so I bail out at the first cross street I can find. I was thinking about installing a pusher fan to be run manually, but there are many options on CFM ratings, The radiator is an 22" aluminum stock replica of the original copper one. If anyone has dealt with a similar situation I would apprceiate your thoughts, Thanks
