Pushing brakes raises idle??
thejohnnyguy
Young Gun
Charlotte
When I pump the brake the idle raises a few hundred RPMs... for just a second or two then drops until I pump again... is this normal?
I bet it's normal. Just push them once, do understand you "pumped" them as in multiple times?
You have to remember that everytime you actuate the brake pedal, the engine has to evacuate the booster again, so there's a little "puff" of air goes into the intake manifold.
Might be your idle screws are a tad on the lean side.
