pushrod lenth
daryl h
Looking for an ajustable push rod to work on the geometry on motor. I know harlydavidson has an ajustable push rod. Is the length compatable? Is there any one that makes an ajustable one that has the cup an ball ends? Believe the length needs to be about seven an a half to eight an a half.
Do they make a cup an ball one for a roller set up?
yeah they do make one for ball end and i think cup end type pushrods too. i want to put some 1.6's on my motor which are full roller aluminum so im looking into buying the ball end type. i found one made from comp cams @ Summitracing p# 7702
