Spoke to a few people and apparently the brackets that mount to the block that the mounts bolt to are different between bodys... B vs C. What brackets do I need to do a big block swap? Thanks, Mike!
HemiSSDart, I have the mount kit packed away. I thought it only has the biscuits. Thanks for the info though...I thought the Schmacher kit had everything you needed? A factory big block drivers side mount is unique to Darts/Barracudas and 65-68 C-Body's. The passenger side is the same as any big block Mopar.
