DusterBoy15
THE WISE(guy) MEMBER
ok so when i install the cam... is there a way i should do it? becasue i know i have to put the special grease on it but is there a good way to install it so that i dont hurt anything?
also when i install the distrib. is there anyhting special i have to do?
and to set the timing for setup is all i have to do is match the crank slot with the cam slot?
