As a matter of fact, NO 67 Cuda had chrome trim around the front or rear window. It wasn't until 68 when they had the chrome trim, which was held on with clips mounted to the body frame around the window opening and somewhat hidden by the window gasket. In 67, the window was put into a gasket and an expansion strip was inserted into a track in the gasket to expand it and help keep the window in. Thsi method was also used on 66 and earlier cars!!
Now the hot ticket is to strip the windows and gaskets from 67 cars and install the clips, then use a 68 and up gasket and the chrome trim. Voila, instant bling!!!
Hope this helps, Geof
