Question for swappng aftrmkt steering wheel.
cudaspaz
In a tree near you.
I want to put a grant steering wheel or something similar on my 67 barracuda, but I wanted to know if I needed any extra adapter pieces to make the swap possible.
My steering column is out of a 70 dart, manual on the floor.
Thanks.
Pick your wheel style,then get the adapter that fit's it and your column.There's all kind's.Hope this help's.
Install kit 3314 should do it.
Grant has a wheel out now that is very close to a rimblow. Not sure exactly what style you are looking for.
Heres there site. www.grantproducts.com.
Check out the Challenger Series.........#860 and #870
They also have Mopar horn buttons.
I am using the Grant wood wheel. It is the same as there tuff wheel. Just used the Grant install kit. Did not need an adapter. You will have to bend your turn signal lever a little but other than that it will fit right on there.
