questions about super six conversion
68darrt
Ontario, Canada
hey, ya i recently bought a super six 2 barrel manifold and carb set up and i will be switching it onto a '68 slant six with a 1 barrel. I have read some of the other posts and i see that i need a new kickdown and throttle linkage. i was wondeing were i could get that from and if it is just a stright swap with the 1 barrel stuff?
yep you will need at least the kick down linkage from a 2 bbl carb or a lokar cable.
you might need:
Choke mechanism off of the 2bbl car.
Throttle cable.
Modified fuel line.
The modification is simple enough but if you are missing something you might get half way through and realize you're missing that one little piece.
here is the full story
http://www.slantsix.org/articles/supersix/article.htm
