They go in from the bottom and the passenger side is the easiest to do and is a no brainer,the drivers side is a little tricky,so I would do the drivers side first and finish with the passenger side.Loosen the engine mounts to be able to lift and tilt the motor to place the headers easier,Mrmopartech
