Hi. I think I know the answer to this but I wanna check it with the crowd. I got this cool aluminum bottle that I'm going to use as a radiator overflow bottle. It has a nipple on the side of the bottom (straight through the wall - no tube inside). The cap has a rubber seal. I think I should drill a 1/8" hole through the cap to allow air to escape as coolant moves in. Does this sound right?
I'm replacing this beautiful temporary solution that has been in operation for the past 20+ years (yes the tube goes through the cap and down to the bottom).
Yeah it does pressurize. I think I'm just going to drill a small hole in the top.
The neck of my radiator has the nipple for an overflow and I'd hate to have coolant blow out freely if it decided to. So I'm going to install this thing.
