Quick question re ‘67 vs ‘68 barracuda front fenders
7T Swinger
Is the marker light hole on a ‘68 the ONLY difference between the two years?
Thanks for your time.
Much appreciated.
Graham
There is also a plastic mounting tab for the headlight bezel on the 67 fender thats not on the 68. Other than the round marker light hole they are identical.
The fender badges are also in different locations, so you'd have all those holes to fill. The 67 has 5-7 holes in each fender for badges (script, fish, V8 engine callout).
IIRC the '67 headlight bezel uses one more screw hole than the '68 also.
