R3 resto block billet 4 bolt main caps
dartrunner
Active Member
pennsylvania
Rating - 0%
0   0   0
I need a set of pro gram billet 4 bolt main caps for a mopar 340 r3 resto block. The caps are stepped and have the straight outer bolts not splayed. I would like to find 1 to 4 but I will settle for 2,3,and 4. If you have a set or know where I can locate a set pm me. Thanks and as always Mopars Rule!!!!!
I have a set.....I think they are Milodon ( Gold irridite finish ) for the stock block.........I have no idea if the register is wider for the R-3 / replacement block , but they might work for you.
If you have some measurements for the width of the cap and the width of the register where the cap fits into the block , I can check and see if these will work for you.
Let me know if you are interested.......I got them cheap and will let them go for about the same.
