race car project
71hemigtx
Pinehurst nc
i need a dana 60 for my 68 dart 4spd car my 8 3/4 489case did not hold up. does anyone have one or have A suggestion for the best sorce. thanks
not sure which is best I have chased several dead ends as far as people told me they had one in an older truck but they turn out to be truck rearends not a dana 60
hi BOB THANKS FOR reply i just noticed you are from nc I live about 1.5 hrs south of you i use to fish gaston lake some i live near pinehurst nc
I got mine directly from Strange Engineering, complete with wilwood brakes, 373 gears, detroit locker.
hey thanks for info for the info those 60s look good. I like the green dart my little brother has an unrestored 71. I
I have sum good friends whom helped me weld up a Dana60 from a ford pu sittin in a field for 100 and a junk yard had some ford 9 inch housings with brakes that was damaged for 50.Friends welded it up with the 9in ends and we drilled the drums to fit my bolt pattern,called Moser for the guts.I found 2 sets of gears unused for 100.I got lucky!here is a pic.35 spline since 1996 no problems millions mid 5's runs
