Race small block stroker...what plug?
dusterdoug
Tracy, CA
Title says it all: What are you guys running for plugs in your small block strokers? Our's is 12.2:1, small chamber (RHS) head...
Thanks!
I have 2 sets that I run........I will get the numbers for you tomorrow,drawing a blank. I will post them in the morning. My compression is a bit lower than yours though at 10.20:1
Okay about the CR, at least your numbers will give us a point of reference and maybe we can figure a colder plug from there.
Thank you!!
I run aluminum heads on both my 11.9 to 1 416 and my 10.7 to 1 360 with autolite AR-3924's...
AUTOLITE 3924 Works best for me so far, this is the standard plug.
I Ran the Autolite 3924 Double Platinum plugs that are twice the price and they did
nothing but foul out for some reason. I just checked my plugs this morning and the regular 3924 has a perfect burn pattern.
Dusterdoug,
Is this a stroker build? What kind of fuel you gunna run?
It is a 416, yes. Fuel? 110
These numbers posted give me a good starting point and a REAL auto parts guy can get to a colder plug.
THANKS AGAIN!
Do you guys know if these plugs also come in the MAGNUM base?
That same plug fits an LA head to.
I run NGK R5671A-8 in my E-85 440W8 head SB and 15.4 comp.
That plug is a 5/8 head.
in my 360 w2 i run autolite 63s that mustang is ihe baddest fox body i have ever seen got my buddy thinking ,my swinger devastates his 5.0
Damn that is some compression! That E85 sounds like it does a great job.
Yes it's better than buying C14 at $11-12 a gal so I switched but I have to test it to make sure it is E84-86% not less.There are alot of other guys in the East coast with Mustangs with SBM and BBM in them.
