Just realized I read your original post wrong. My answer implies that the SXT21 has the wider lobe centers & so would want more compression. Its the other way round, the DC 557 has the wider lobe centers, so the DC cam would want a little more compression. I never ran one myself, but I know other guys that ran the STX21 (And the bigger STX22 as well) it ran real good. I knew a local guy that ran a '66 Valiant with a near stock 340, reversed flat-tops, stock X heads, an LD340 with the divider milled and a 2" spacer, 750dp,9" converter and 4.88s ran solid mid elevens. By the way, on the same car I screwed an untouched 850dp on it, immediately picked up a solid, repeatable tenth.
