Racers chime in #2
swifter
wis
OK Men I asked about fluid changes now what about engine tear down inspection??????? how often do you do this?????? Steve
I'm not asking about Nitro motors or anything like that sorry I should have stated the question different OK For the Average Joe who races a couple weekends a month,How often do you guy's tear down and inspect???? At the end of the year???? every two years???? Never???? Just run the piss out of it till something breaks???? ThanksSteve
I would leak down check it every year, and freshen it up every 2-3 years depending on leak down numbers. Some times just a set of rod bearings and lower main bearings is all thats needed.
When it breaks. LOL
I will do a leak down test at the end of the season to see if there is any concerns.
If all is good, I just back off the rocker shafts to remove the spring pressure.
I don't check the rod or main bearings, other than checking my magnetic oil drain plug & cutting open the oil filter to check for metal.
Now, even if you do inspections, it can still blow up without notice.
I have only lost two engines in 30 years, now mind you these are low 11 second cars.
Stock crank & rods.
Both broke do to failed componets.
The last one (360) had 925 passes on it. 5-seasons of races. the worst cylinder was at 7 percent with a cold engine.
The first race of the season, the first time trial, it ran as fast as it ever had.
When it went thru the lights, it had a Kieth Black (KB107) come apart.
Sure, I would have caught it while doing a tear down inspection, but it never gave me a reason to do it.
The other engine (340) broke the crank behind the thrust.
It also had several seasons on it as well. Never gave a reason to do a teardown.
I do have a freind that does tear down inspection every season or two.
Is there any moral to this story, probably not. LOL
Even so, he still broke a rod that he had looked at before.
compression ...leak down test....
maybe change out valve springs once in a blue moon....watch for smoke went it fires up or going down the track...otherwise.....kind of hard for an average bracket racer to catch a rod before it going to break..
or if i can to blow up an engine I put in a certain 71 Duster I own...it seems to be killing them monthly...
When I want more power. Seriously I never leave a combo alone for more than a year lol
