LOL. The reason the right rear drops is that's the side the torque tries to pry off the ground with axle / suspension torque, and since the machine cannot "pick itself up" the next best thing is to pull the body down on the axle. Anyway you look at it, on a non- limited slip axle, the right rear is nearly always the one tire which spins.
Putting more weight on the left side is not gonna fix that.
this is truth. its also the reason that super stock springs were designed in such a way that the right rear of the car is higher than the left rear at rest. the right side in a sense holds up more of the rear "body weight" than the left, thus trying to even out the traction to both tires at launch.
I am clear on what the effects of torque is! I have been racing a long time.
If the op is drag racing why the heck would he have a LS diff in his ride anyway. Spool it at least! The left rear raises off the suspension. You put the weight on the right side its gonna drop more.
Proof in the pic of my 8 second 1/4 hooptie,
Sorry my friend you are completely mistaken. You are most unfortunately NOT clear on the "affects of torque." The torque of the driveshaft is attempting to lift the right rear tire off the ground. The torque reaction of the engine in the chassis is what is "planting" the rear quarter, and your photo is proof you are mistaken. In other words the body, from engine torque, is trying to twist up off the suspension.
In the same way that a broken engine mount lifts the left side of the engine, the left side of the chassis is being twisted by engine torque
The fact is, if your car "hooked" really really good, you might have been better off putting the battery back in the left front corner!!
